Manufacturer literature not recommending or acknowledging Static Contact Resistance or milli-volt drops tests on their low voltage breakers
static micro-ohm resistance.pdf (35.2 KB)
I am writing to ask the community’s opinion regarding this manufacturer’s(Siemans+ “others”) publication regarding contact resistance, and milli-volt drop tests performed on power and molded case circuit breakers.
. We had a breaker that had a pole that was 3x phase to phase comparison as well as 3x like kind breakers in the same environment. I understand the I2R losses weren’t significant, but as a NETA contractor, I reached out to the manufacturer for any kind of compliance paperwork they would provide, and this PDF is what they sent me.
They specifically state that:
" The resistance value usually measured by many third-party testing
companies is irrelevant, and often misleading in new or nearly
new circuit breakers."
" The NETA document “Acceptance Testing Specifications” makes an
arbitrary statement as to the allowable tolerance of this
measurement when no tolerances are stated by the
manufacturer. As applied to Siemens circuit breakers, this
arbitrary pass/fail criterion has no basis in the practical
operational environment of the circuit breaker.For the reasons above, Siemens Industry neither publishes any tolerances for, nor recommends the testing of static micro-ohm or milli-volt drop across the main contacts of any
Siemens low voltage power or molded case circuit breakers."
" Siemens Industry does not accept the NETA "Acceptance
Testing Specifications" as an accurate means of validating the
quality or operational performance of its low voltage power or
molded case circuit breakers. Any test report or claim stating
that a Siemens circuit breaker is not suitable for its intended
application or service on the basis of contact resistance or
milli-volt drop, will not be considered acceptable evidence of
nonconformity for warranty action by Siemens."
NETA says to consult the manufacturer’s literature. In this case, the manufacturer’s literature doesn’t recognize NETA testing as valid. The manufacturer overrides NETA.
With that said, high contact resistance can be an issue. I think its an important check, especially for low-voltage breakers.
Anyone who has done a fair amount of infrared scans can attest to this. It’s still worth noting when there is a deviation, and I would recommend following up with an infrared scan during a period of peak load.
That’s my two cents. Curious to see what others think…
They make some good points. ‘self-cleaning’ An old trick for failing DLRO results was to run several thousand amps through the phase and trip it. Next time it closes, breaker usually ductors fine, often works better than scotch brite.
I agree on the order of magnitude point somewhat. 20-200 micro ohm they say it varies to much to reasonably compare. I agree with anything under 50. i see 4000 amp breakers give 15 and 23 micro ohm and that shouldn’t fail but technically does. but a 600 amp breaker is in the 70s, those almost always trend with each other and they should, if you investigate outliers in that range, you’ll usually find issues
