Siemens WL breaker locked in closed position
While replacing a moveable contact; the moveable contacts locked in the closed position. I’ve separated the mechanism from the frame but I am having trouble figuring out what it is that is locked up. Any help is appreciated.
I never got any replies, but I did get the problem solved. If anyone ever has this same issue you can send me a message and I will help you through it.
What was it??? Did all 3 poles get stuck?
