I am trying to get proper TTR test results but having issues with every method I try. I have tried the T-T lag 30 and T-T lead 30 along with random tries. Any help with figuring this out would be awesome!
Thanks in advance!
Thanks in advance!
I’m not to familiar with this particular type of transformer but this would be my first stab at it:
H1-H2 - X1-X0
H2-H3 - X2-X0
H3-H1 - X3-X0
H4-H5 - X1-X0
H5-H6 - X2-X0
H6-H4 - X3-X0
H7-H8 - X1-X0
H8-H9 - X2-X0
H9-H7 - X3-X0
I may be completely wrong on this lol. What kind of test kit are you using at what are your connections? Also would be good to know the exciting current.
Hey Michael,
To get accurate TTR results with this T-type transformer, make sure you’re considering the following:
Vector Group Check: Identify the vector group configuration of the transformer (e.g., Yd11, Dy1). This will determine the phase shift between HV and LV. The phase shift setting on your TTR meter needs to match the transformer’s configuration.
Phase Shift Settings: Make sure your TTR meter is set for the correct phase shift (e.g., T-T lag 30 or lead 30). Mismatched settings can throw off your readings.
Connections: Double-check all connection points on both HV and LV sides. Any wrong connections can lead to erroneous results. Stick to the manufacturer’s recommendations for connecting to each winding.
Polarity Consistency: Keep consistent polarity across all measurements. Any mismatch in polarity between HV and LV can skew your results.
Neutral Handling: If the transformer’s neutral (X0) isn’t supposed to be connected during the test (as per the diagram), make sure it’s left unconnected. Connecting it can impact your readings.
Instrument Calibration: If you’re still getting odd results, verify that your TTR tester is properly calibrated. Sometimes the issue could be with the instrument itself.
Hopefully, this helps you get the results you’re looking for!
Thanks!
This website is not affiliated with, maintained, authorized, endorsed or sponsored by the International Electrical Testing Association (NETA) or any of its affiliates. The information presented on this website should not be used to replace any kind of classroom or group study led by a certified instructor. The use of all copyrighted material on this website is provided for the purposes of teaching, scholarship, and research, and is therefore considered to be covered as "fair use" as specified in 17 USC § 107 - Limitations on exclusive rights: Fair use. If you are the owner of copyrighted material on this website and feel that our use of such material is not covered under 17 USC § 107, please contact us. TestGuy.net is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to amazon.com. Copyright © 2026 TestGuy.net. All rights reserved.
